still wanting to die. | Ford Explorer Forums
bcdescd22
Louisville KY
95 XLT
OK I have a 95 explorer with 120K on it. It still keeps wanting to die when I start it only sometimes. I replaced the idle air control,egr valve,egr valve position sensor. The spark plug wires and plugs looks fairly new. And sometimes when im using my cruise control it jerks back and forth. But Im getting around 300 miles per tank? Does anything think its the MAF sensor? Or the TPS sensor?? :mad:
btw no c.e light and no engine codes and fuel filter was replaced
Check for vacuum leaks. Make sure all the lines aren't cracked/loose, and that none of the caps on unused ports are missing or cracked on the "octopus".
Try cleaning the injectors. They could be dirty, my 1994 did something like that before.
It's also known as the vacuum tree. All vacuum lines originate there.
I have a ? I have an 95 Explorer with 160,000 miles on it just when the weather was getting warm it started to act up on me..rough idle..startup...when i would drive around for a few hours i would come to a stop sign or a stop light and my truck would act as if it were going to stall out but it didnt...i cleaned out the IAC two times..and still nothing...when i start it up some times the idle will go up and then go back down...it will do this for like four times and then idle smoothly...please help
