broncomitch
- March 30, 2013
- West Jordan,ut
- 2005 explorer
I just got a 05 XLT with the 4.0 v6
The main thing is the A/C clutch won't kick on.
The explorer was wrecked and fixed and they didn't charge the a/c,
So when I came to pick it up he tryed to charge it but the clutch wouldn't turn on and said to bring it back when I get it going.
So I tested the clutch and its good, checked the fuse's and relays and the low bypassed the pressure sensor and still nothing...any idea's on where to look next?
The other is sometimes when accelerating it sounds like the climate control fan is blowing...
And when I was checking everything over I checked the tranny fluid and it had never been changed (92k) so I just dropped the pan and changed the fluid and filter and tryed to get flush out as much of the crap in the system.
When I filled it up (witch was a joke) it started shifting hard..so checked the fluid level and still good.
It started shifting smooth again but will still have a harder shift here and there..and it shifts from 3rd to 2nd to 3rd again..(smooth shifts and not sure if those are the shifts but you get the point)
Also the traction control light is on and the computer says check advantrack.
The body shop I bought it from said the module was bad..where is the module??
I have been searching through the threads but can't seem to find any answers.
Any help is appreciated.
