Pavesa
- May 10, 2020
- Canning, NS
- 2007, XLT
Hi
I have a 2006 Explorer V8 4.6 liter with 141,000 miles on the clock. It's in really great condition. I bought it a couple of years ago and it's used as a work vehicle for towing 12' - 14' trailers with weight up to about 1,000lb.
It has developed a strange vibration that kicks in at around 50mph and increases to about 60mph and then persists at the same level from there on. It feels very like a wheel is severely out of balance. I had my mechanic drive it with me and he thought it was a wheel out of balance and told me to get them balanced. I had them balanced and it made no difference. If I'm going down a slight incline and move the gear shifter from D to neutral and let the engine idle, it makes no difference to the vibration, so it seems not to be engine or transmission related. I get the same thing whether I have my winter rims on (Toyo) or summer (Good Year). My mechanic checked things over - the U joint - fine, everything was tight in the suspension, axles/steering rack seemed fine. He has a theory that Ford has some proprietary additives to go in differentials that make it run smoother, but I'm not really convinced that's the explanation. I did find this although the Ford Technical Service Bulletin is for 2002-2005 Explorers but the post was about a 2007 Explorer that would be the same as mine and I have the problem in all gears whether or not the overdrive is off (the TSB refers just to 3rd gear overdrive off).
www.explorerforum.com
I'd be grateful for any thoughts.
Thanks!
Strange humming/vibration
About a month ago I was driving on the expressway and I heard a klunk. It sounded like it came from the front drivers side. It actually sounded like my tire blew out. I hurried up and got over to the slow lane in case my tire was going flat and... nothing. All the gauges stayed good, tire...
Thanks!
