Matt98svt
- November 26, 2016
- 2007 Eddie Bauer v6 4.0
So my 2007 4.0l V6 has had a noticeable oil leak from the back of the engine for awhile. Always contributed it to the rear main seal as it has 225k on it. Well recently had a new (used replacement) transmission put in and the rear main seal replaced and still had the leak. Decided to change out the oil pan gasket but first thought i would check to see if all the bolts were snug only to find a stripped out bolt on the back row of bolts holding the pan tot he block. Need to correct this before putting in the new gasket and trying to decide if I should put in a helicoil (which i have never done) or drill out the threads and tap a larger bolt to go in? Any advice on repairing this and what size helicoil i should look at installing?
