Stuck drivers power seat | Ford Explorer Forums
comserte
Miami
2002 Sport trac
Hello, hopefully someone can give me advice.
My 2002 sport trac needs the driver's seat upholstered. Took it to get it done (by the way $120.00) to re do entire seat in matching leather. They can't remove the seat because the rear bolts are not accesible. Tha power seat moves back all the way but forward only partly. Any ideas on how to remove this seat? If we can't see the rear bolts how can we do this? Is there a way of disconnecting the motor so the seat can move manually? I called the dealer but it sounds like a $600 job to spend $120 in leather. Any thoughts are appreciated.
Most likely there is a coin or something on the screw drive.
You may be able to remove the seat from the seat frame from underneath depending on the orientation of the retainer bolts.
