I have the 4.0L with I believe the OHC.
This vehicle is actually a nightmare!! I have done so much and continue to do more, but cannot afford to get out of it right now. In the past year, I have had the following done:
Transmission rebuild
front and rear differential reuilt
Transfer case rebuilt with encoder motor replaced
Cam synchronizer and Cam Position Sensor
Throttle position sensor
MAF
I had replaced the IAC a little over a year ago
intake and valve cover gaskets and new plenum
The stumble on WOT was an isolated incident. I have noticed that I do have a rough idle but it idles at like 800 RPM's in park. I have also done the EGR valve and pressure regulator (i think it is called). When I get on it it goes. Seems to run better in the cold.
My biggest problem right now is that the transmission seems to be "off". My shifts seem to be right there, but it seems that when I want to go, it is always reving out. There does not seem to be any slow progression to highway speed. Also, when I am on the highway at speed, there really is no maintaning....the slightest feather on the pedal and it seems to "kickdown" RPM's go up an then it shifts down....I also noticed that it seemed to run at an RPM, then go up about 200...then drop back down, then up, back down and so on.
I really do not have any idea what is going on, but I want to try and get my truck running the way it has in the pass. No CEL or noted codes...Right now I need HEEEELLLLLLPPPPPP!!!!!
