Hi All,
Yesterday I replaced my Ford Explorer battery with one obtained in Ireland in a car parts shop. Stupidly I never thought to check that the terminals were in the places I ASSUMED they were (of course they were not!).
I seated the +ve lead and as I attempted to push the -ve Iead on there were sparks, pump sounds and then smoke from the the fusible links. I withdrew the -ve cable as soon as I saw the smoke. It took me a while to realize what had actually happened and now I know I feel stupid.
I can't believe it. After completing a clutch replacement on a mkII Ford Mondeo manual requiring subframe removal and many other sub-procedures I come along an do this?!?
Anyhow, I might have escaped the worst. The radio/navigation fuse was blown and I limped home with a failing battery because the alternator is no longer charging!
I don't get a voltage reading between the Alternator upper wire (heavy duty charge wire) and the battery -ve terminal and the voltage across the battery terminals is down to 11.4 and falling.
I'm in work now but going home to do some more tests. I am hoping the narrow gauge fusible link wire is fried and replacing (bridging temporarily) this will bring my baby back to life.
Does anyone know if the two wire electrical connector to the Alternator/Generator can prevent it from producing a charge if for example those wires were damaged? I'm guessing they are there to control when the alternator generates power... but I don't have a wiring diagram yet.
Also can the Rectifier board be replaced if I fried it? Or do I need the complete new alternator. Some european Fords over here have similar looking motorcraft alternators in terms of mounting holes etc but may be geared differently for different rev profile. I fear this will not be cheap as its a 10 - 20 pound component posted from USA to Ireland if I have to go down that route.
... not to mention what other systems I have disturbed / damaged that will now fail shortly.
