jahna
- June 22, 2006
- WI
- 99 xlt
Hi Guys- This morning I replaced the fuel filter, did plugs and wires. While under the X I noticed 2 broken sub frame bolts, one broke on each side. This is the cross member of the sub frame, it bolts to the 2 main frame beams. The cross beam runs under and supports the transmission and front end of the gas tank. I'm assuming that these bolts have been sheared off for some time. When I bought the explorer (at 100k, now 120k) it was completely missing sway bar links on both sides in the front. I wonder if the body roll helped shear these off.
What should I do here? I could just have it welded to the frame but I would think that this approach could be problematic if the tranny or gas tank needs replacement. Other option is to have a show drill and tap a new hole. Anyone know what I should expect to pay for a service like this? Any other ideas are appreciated.
I also tried finding the source of a slow transmission fluid leak and found a missing transmission pan bolt. Does anyone know where I could source one of these bolts? I should probably just try the stealership.
Thanks-
Thanks-
