SCB2525
- August 5, 2006
- Richboro, PA
- 1996 XLT
Help!
158k, A/C (if that makes a difference), not sure of the model transmission but A4LD rings a bell for some reason (perhaps its in the owners manual, I've read it a bunch of times).
I was driving around tonight and at one intersection, I set off to accelerate and it wouldn't shift into second. It only will do so if you get the RPMs above about 3000 and then let off almost all gas. The O/D OFF light started blinking shortly after. Later when almost home, I almost got the revs to where it should shift but I was approaching an intersection I needed to turn on and slowed to a stop. While waiting for it to clear a few seconds later, completely stopped, the whole truck slammed and felt like someone hit me in the rear. No one was behind be so the only thing it could be is the tranny was trying to shift about 10 SECONDS after I started to slow below where it should have shifted. This happened once more before I got home.
All this started quite suddenly and the transmission was shifting normally up until when the problem started.
Any ideas?
Any ideas?
