what radical modifications would need to be done? want to keep it under 10 thousand
Instead of replacing the whole engine with a Cobra motor, what is involved in fitting the same Eaton M112 supercharger onto a stock 4.6 V8. Obviously I would have the charger, but what other bits are needed, and is a tune required?
You will not be able to keep your total cost under $10k if you want to swap the Cobra motor with its trans over to the X. About the only way you could do it for less than that is if you found a wrecked terminator for a REAL good deal and did ALL work yourself. I don't know if even I could do that swap for less than $10k and I do projects like this quite often.
Rather than doing a pretty sizable and custom project like the one you mentioned in your first post why don't you just do a custom supercharger project onto your stocker 4.0? While it will not be able to make the power the Terminator engine is capable of it will still be able to put down some pretty respectable power. RPCaster from the Ranger site make custom intake manifolds to allow an Eaton M90 to be bolted onto the Explorer/Ranger 4.0 V6 engine. There was a member who did the M90 onto his gen 3 4.0 V6 Explorer not long ago. Search around for it if interested.
Just remember that if you end up planning to go for the big power (500+rwhp) that it will cost quite a bit of money. There are allot of "smaller" upgrades that need to be done to support the bigger ones making the power. It all adds up pretty quick. There is NOTHING except for the rear end that is stock within the drivetrain of my Exploder. Everything has been upgraded to hold around 1,000hp just in case I decide to push it that far in the future. Trust me when I say that most would vomit with disgust if I actually disclosed the dollar amount that I have spent on parts alone for this truck; let alone the amount of hours or wrenching I have invested. If you want serious power you will end up having to pay the price. $10k will probably not be enough for what you intend to do when it is all said and done. Best of luck with whatever you do.
hey bro hows the truck running? you were in the middle of your build/tune when i traded the ex in and got my lightning and left these boards. what kinda numbers did it put down? you went kb 2.3 right?
pullied im at 405/522, wanna race?![]()
Hehehehe. Just started pulling it back apart to do the Modular Powerhouse heads, blower cams, fuel cell and A1000 fuel system as we speak.
I would be happy to race ya, but I got to warn you I should be hitting about 600+rwhp on the blower alone before nitrous so it may not be a fair run for ya.![]()
