Supercharger install 9+lb boost! Full build | Page 39 | Ford Explorer Forums
Thanks guys
I was worried I messed it up lol
So the wife went into the basement ...my work area... she said what the hell is that I said it's a new lawnmower engine isn't it cool I'm going to hell for this I'm in to deep to stop now
I'm waiting on some parts in the mail however I am gonna install the fuel pump this weekend
I already know the feeling Bud...
Update
We finally installed the U. joints The factory ones started sounding like crickets
The rear u joint ended up having water damage
The seals have gotten hard
I did purchase a ball joint press Made the job very easy
We clamped The ball joint press In the bench vise Worked a treat
Update
The rear view joint ended up having water damage
Always good to hear updates on your Explorer!
My transmission voluntarily self-destructed so it makes upgrading easier for the supercharger install. Did you do anything special to your transmission's 'guts'?
I had it rebuilt
The rebuild guy did upgrades I'd have to look at the paperwork
Ask your rebuild guy what upgrades he can do
I had it rebuilt
Jeg's actually has off-the-shelf upgraded transmissions with same kit as 5.0 'teenager-vs-telephone pole' Mustang transmissions.
Seems like everyone who says they 'repair transmissions' just order off-the-shelf replacements anyway. hard as heck to find someone who knows what the sign on the front of a 'transmission shop' implies. :/
Thanks!
Thanks!
If I remember correctly there wasn't too many speed related upgrades that could be done the frictions and steel plates were upgraded in my transmission but I am not sure on the details it's been a few years
All of the real upgrades were done with new valve body and stuff done to it
all factory Recommended stuff
I did install an external transmission cooler filter
And I change the fluid once a year
I just suck as much as I can get from the dipstick tube Usually a gallon
At 50,000 miles I adjusted the bands
^^my man
Everyone neglects the band adjustment
@donalds …. With your external transmission cooler, you probably can disconnect both of the lines, then run them into a bucket … just measure the removed fluid, then add that much more new fluid. You can easily exchange as much transmission fluid as you want.
I do this annually for two consecutive years, then drop the pan to change the filter on the third year. Just an idea…. What do you think?
That's exactly my plan for next time
I have a filter there when its due to be changed
Ill try that method
Oops, you need more boost to counter balance that 16psi of coolant. :p
Just read through the whole build. Really nice job!
