Supercharger install 9+lb boost! Full build | Page 12 | Ford Explorer Forums
I noticed there are two types of 90 mm lightning maf sensors
A ford unit
For Ford F150 SVT Lightning & Mustang Cobra New OEM Mass Airflow Sensor MAF GAP | eBay
Or a Sct unit.
SCT BA-2600 Mass Air Meter 90mm for Ford Mustang/F-150 Lightning/Harley | eBay
not sure how keen you are with used parts, but you might or should be able to find either or of those throttle bodys on corral.net. i found my lightning maf, injectors and fuel pump there and have had no issues
Ditto, most popular parts can be found for a little less from forums or eBay etc. If the price is not a lot lower than new, I then tend to take the new part when I have to have it.
I was gonna buy new
Just not sure what is the best sensor to go with
Sct or oem
Those are the top two best choices.
my personal opinion if you dont mind spending a little more cash, sct.
That seems to be the consciences
I'm trying to get a very good idea of my parts list
That way lasota can kinda approve or change it
I already have the #47 injectors so I hope that won't be a problem
Yea I'm seeing that... Now lol been looking to do this swap on different cars still looking into it I'm going to see if they got one of these chargers around pfft idk with the prices might look at a different project anyways why are the superchargers I have found at the junkyard seem to be no good? I was assuming heat but now I'm thinking oil. That's totally different I'm thinking he won't actually have any heat issues on the supercharger itself.
Roots and twin screw superchargers are fairly durable. This is why they are used by the manufacturers. If the oil in them is changed every 50k miles or so they typically last 150k-200k miles or longer. Check into rebuilding them. It might not be that hard or expensive to do. Especially for Roots blowers.
Ok guys
I am following the moddbox 9.5 psi build
This configuration is running on mustang rangers with this engine
The #47 injectors are still in the box with the adapters
The throttle body is bigger than my stock but is a stock tb from a 2005 ranger as the moddbox guy said to use for the boost I'm looking to run
I'm gonna ask lasota about the Maf most likely a lightning maf 90mm
Here is the meth water kit I'm looking at
I can put the spray nozzle before or after the blower I was gonna move THE air intake sensor to directly under the blower as their is a pipe plug their now
It sure would be great if @moddbox cold give a Maf suggestions because well he built the kit lol
The water/methanol kit looks pretty good. It has customization for onset and full pressure which helps a lot for dialing it in during tuning. Although with a Roots blower full boost happens so fast that the onset setting is irrelevant. It does help when you are rolling into the boost during less spirited driving. Why I chose a twin screw blower was for the instant full boost it generates and any RPM which makes an engine feel like a built big block.
One thing that helps is setting up a temperature probe in the intake track after the blower and after the spray point. This can give real time info that helps dial in the spray setting and which nozzle to use. I used a dual temp digital thermometer and had someone monitor temp reading under boost. These days I imagine there are ones that will log temps and not cost an arm and a leg to buy. Lasota is a great tuner so they should get it all dialed in right for you.
I recently made the decision to not intercool nor would I use meth/water injection for my daily driver. At least no intercooling for a while.
Intercooling may happen, but would require I make a custom unit and a transfer case upgrade to hold-up to the power.
I do not want to rely on meth/water injection for cooling on a daily basis. My rig does run in boost for long periods when climbing to the west out of Denver and would require a good sized tank. I think it would be an additional thing to go wrong and to deal with for a daily driver. My engine is worth more to me than what would happen at higher boost levels if an inexpensive meth/water injection crapped-out...............................and I was only gaining a few pounds of boost to run it in the first place!
I installed a J&S Safeguard in my 5.0L and swear by them. They work incredibly well. They control timing on an individual cylinder basis and adjust timing to each cylinder each time it fires depending on if detonation occurs in that cylinder. I bought mine in the late 1990s so J&S been around a long time. If you are concerned with keeping your engine safe from detonation then this is a good way to do it. These units cover any situation that can cause detonation like bad O2 sensors, bad gas, carbon buildup etc. as well as running more aggressive tunes.
Thanks for all that advice guys
I'm enjoying this thread and all the side talk to
Keep it up
Orders parts today
I still have the ford racing #47 injectors
Oh ****, gonna go faster!
Very good, those parts will help. The MAF I have someplace to use on one my projects, the same 2600 model.
Got some Parts. Maf and fuel injector connector s pigtails
Man that maf looks huge 😊, bet your getting excited.
Orders parts today
Looks like you are going to find the weak link in your drive train. Been there, done that....... several times. ;)
That's what she said lmao
I really am this stuff is fun to me
And Jess my wife don't beat on it either
She likes to pass people
Keep in mind I've been working on this build for a while
I did a big mod once a year
First Year
was the trans full overhaul Inc hard parts shift kit and more
And rebuilt the rear diff
Second year
was the engine and any and all components needed metal thermostat housing sensors ect...
Year three
Supercharger installed
Year four
Electric fan conversion more boost a tune gauges ..
This is the final year
Then I'm gonna build one for my daughter
My son wants a dam Honda smh
Ok what did you break?
was it on this drive train?
Your getting me worried now
The hardest pulls will be the data logging and tuning
