Ok, I'm not really talking to myself here even though the last three posts are mine.
Anyway, Robert peaked my interest in the motor. I had to do some poking around to see just how this variable intake system worked. To make a long story short, I couldn't find it.
Here's what I did find. I first took the plastic cover off the intake manifold assembly. The throttle assembly is right up front with the accelerator and cruise control cables attached to it. Then the manifold splits into two pipes, one going to the left manifold tube and one to the right tube. Right at the split is the EGR tube. From each tube, three runners drop down to the heads, the three from the left tube go to the right bank of cylinders, and the three from the right go to the left bank. Kind of looks like the cross-ram setup that GM used on firebirds.
Anyway, between the two manifold tubes is a solenoid valve with a smaller (about 7/8") pipe running to it from just on the engine side of the MAS in the air pipe. I first took the solenoid off and it is indeed an electrically controlled valve that when it opens allows flow from the small pipe to the intake manifold. I removed a seperate piece that the valve connects to from between the manifold tubes. Under that is a crossover that connects the two manifold tubes. There is no valve in the crossover, so they are always connected. The only thing this piece I removed did was allow the air from the 7/8" pipe to flow into both sides of the manifold.
I stuck my fingers into each manifold tube to see what might be in there (like a vacuum controlled throttle valve kind of thing). There was nothing there. I could feel the intake pipes on each side, as well as a couple of the runners that drop down to the heads.
I'm suspecting that this 7/8" pipe is just part of the emissions system. I don't think it's big enough to boost air flow enough to give a serious kick. What am I missing here? Is the SOHC engine different in later models?
