SuperLift IFS Swaybar end-links Mod?? | Ford Explorer Forums
DrKlawz
Denver, CO
2000 Ranger XLT
I've got the Superlift kit for the 98 and up IFS installed, and the swaybar links don't seem to fit too well. I've heard tale there's a mod that somebody did to correct the banging...
I'd love to know! Got a trailrun this weekend, and if I don't correct them they're coming off!
Also... anybody know who makes quick-disconnects for Ford Ranger/Explorer swaybar end links? If not, its fabbin' time!
I don't have that lift but:
For the front swaybar I can take off the stock endlinks in less than 5 minutes. In the rear I have quick discos made by Warrior.
BTW, welcome!
problems w/ Superlift
The stock ones I could whip off, but the superlifts are a little more jacked. Right now I'm in the process of trying to mod them so they stop banging...
Superlift has a spacer on the bottom end-link bolt that passes through the arm. Problem is the damn bolt is too short for a couple of bushings, and to small to fill the hole. They include a spacer, but the spacer is thicker then the steel of the lower support, meaning that even at maximum tightness, the nut doesn't go flush and it bangs like a screen door. I'm open to suggestions...
I took off the spacer and used a hardened washer on each side and tightened it until the washers dished in towards each other.No more rattle
that's the plan!
After pulling them off last night, I think that's the real problem. I'm going to go pick up a little hardware tonight and see if I can dog it down.
I also cooked up a plan for quick-disconnects, but I have to see how it pans out. I'm going parts hunting tomorrow.
