roadrunner001
- January 6, 2008
- Fife, Scotland
- 98 XLT
I've serched the forums and suspect I need to clean the MAF however as I have NO mechanical experience I wanted to check with you guys first.
Basically, starting first thing in the morning is always first turn of the key, idle goes up to around 2.5k and drops to 6k ish, idle alternates between within this range till the engine has warmed.
I don't know if it has anything to do with it but also when cold I need to drive at least 3 miles before I get what I would regard as normal throttle response, it just feels like the car hasn't woken up yet. is this normal for the Ex, if so I'll live with it but if it's a symptom of a problem I'd like to sort it out.
cheers.
Graham.
cheers.
Graham.
