suspension lift help. | Ford Explorer Forums
DEERE6030
Omaha, Ne
99 FORD RANGER XLT
i have a 99 ford explorer V8 xlt and iam thinking about going spring over axle in the rear and i need to know more info about that and what lift kit i need to buy to lift the front to the same hight as the rear after the SOA!?!
the trucks my bothers if your wondering
SOA lifts the rear approx 5-6 inches, at least on first gens, so it should be the same.
there isnt an ifs lift that i know of that will pull the front end up that high. youd probably need to go solid axle in front if your goin soa in back.
ok so my best bet is to go with the superlift!
Althogh i was searching the forum yesterday and i was looking at pics of this guy doing a soa on a 99 explorer and he didnt say what he used to level the front. Id really like to know though.
there may be a 6 inch front end lift, but i haven't head of it. if you are just lookin for height, a body lift, and shackles/torsion twist will give you about 5 inches.
Brake light problems need suggestions!
I need help on why my brake lights wont light up when the brake pedal is pressed; I checked all the fuses their good, I checked the bulbs their good, I put in a new brake switch, The brake lights will illuminate when u turn on the headlights but when u press the brake pedal they don't get bright, even with the headlights off...suggestions please
Can i fit 33x12.5 on a stock 15 inch rim? and will it have any rubbing issues with a 4" susp. lift? fyi its a 99 AWD explorer, is it worth putting a 4" susp. lift? will it work?
