Suspension Problem? | Ford Explorer Forums
Suspension Problem?
SCzerosix
Evergreen Land
1999 Eddie Bauer
Hi guys I need your help here. I got 1995 Explorer Limited 4wd two weeks ago. The problem is that I when its parked on leveled parking lot the drivers side rear looks lower than normal (like 2 1/2 inch). I'm guessing either it might be the leafspring or the struts but I'm not sure. I hope you guys could help me. Thanks! :)
One thing is for sure, it's not bad struts because 1994-2001 don't have them:)
It's either (and most likely the leaf springs sagging) or it could be the air ride control since you have a limited.
2.5" sounds excessive for a weak drivers side leaf spring "Ranger Lean".
Check underneath, don't be surprised to find something loose or broken.
Hi guys sorry for the late reply. I've been busy these past months so anyway my 95 Limited has an Air Ride Control System. And I made a mistake it's between 1/2 to an inch lower than stock height not 2.5" (sorry swshawaii). Now my question is it possibly the air shock/air bag have been leak? Thanks.
It's just the gangster lean. More weight is on that side: driver, gas tank, front diff, t case.
