Suspension related alignment problems | Ford Explorer Forums
JThelen
Cumming, GA
'94 Limited
hey yall i got a 94 x 2wd and i put on a 4 in skyjacker susp. lift and i would like to know if any of yall know about it causing the axel to bend at all so that it could not be aligned cause i took it to get aligned and the dude said we cant do it the susp must have bent the axel... i was like umm ok
WAT DO I DO??!
thanx -Jason
Go to a different allignment shop. It is possible that your allignment won't be perfect, but a good shop should be able to get it close, especially with a lift that has the same height springs as drop brackets (no spacers). A good shop will be able to tell you more than what that guy did, what is off and why, etc.... I've never heard of a 2WD i beam bending, could be in the balljoint or something, but I doubt it.
