ejs1097
- February 1, 2005
- PA
- 97 XLT
I have the infamous knock going over bumps and everything is tight on the front end. Based upon past threads I'm going to replace the sway bar bushings. The explorer is alot different then the van that I recently did the same work on.
I've found lots of topics and info by searching the forums but none that actually mentioned how to change them. I have a few specific questions, even if they seem stupid to some, about the job.
0) Is there a certain order of tasks in order to get the bushings off? (ie: loosen inner barckets to get end links off, etc)
1) I can't find a nut holding the inner bushing bracket, is the bracket tapped to accept the bolt?
How do you replace the end link bushings:
2) Is the bolt on the top extend through the entire link to the nut on the bottom?
3) If so, is there any issue knocking the long bolt back out? It seems it'd be close to hitting the control arm.
4) Do you have to take the whole bar off the frame to remove the link bushings or does the bar just need loosened?
Any other info I may have missed will be appreciated.
Eric
Eric
