sway bar bushing size | Ford Explorer Forums
doc dukes
Fairfield,Pa
94 XLT
I need to get new sway bar bushings for the front and rear of my truck but I am seeing a few different sizes. Just wanted to know what the diameter is for the stock sway bars front and rear. If anyone has part numbers for energy suspension poly bushings that would be great too. ;)
I just did mine as well...
For the front on mine (4X2) it was 3/4" I believe....
the only ones I keep seeing are the 25mm and the 28.5mm.Mine is a 4x4 I am not sure if that makes a difference or not.
I wouldn't be sure for the 4x4, but mine was 25mm.
I think I am going to go with the 25mm. That seems to be the most common size I keep seeing. I am going to get those and I will let everyone know how it turns out.
Update for search purposes
The front bar size turned out to be 23mm. The rear size turned out to be 5/8s.
