koda2000
- September 2, 2011
- x
when i first test drove my 5.0L RWD 2001 Eddie B. w/180k on it last summer, i immediately noticed that when turning the steering wheel at low speed (like when getting out of a parking space) i could hear kind of creaking/binding in the front end. upon inspection i noticed the ball joint boots were all but gone and the ball joints looked rusty. i replaced the upper control arms and lbj's last fall, with Moog's, and replaced the sway bar end links while i was at it. the tie rod ends seemed good, so i didn't mess with them.
well, it still makes the same noise. now i'm thinking it might be the sway bar bushings. pretty easy fix if it is, but they don't look bad and it's seems to me to be more of a dry metal-on-metal kind of noise ??? i've noticed it only makes the noise after driving a while. backing out of the garage cold it never does it. any thoughts?
if i do replace the sway bar bushings i'm thinking of going with Energy Suspension with grease fittings. i don't know... maybe inner tie rod ends?
