sway bars | Ford Explorer Forums
sway bars
Most of the ones I see are just people replacing the lower bolt with a hit pin type. Its simple and works.. I can't comment on how well it works as we don't bother running any sway bars.
~Mark
I went to the local farm supply and picked up some pins and R-keys.
In my case, I ended up getting a drill and bit and barely opening up the sway bar end links.
I leave one side bolted up, and remove the drivers side link totally when I wheel.
It might be better to remove both, and strap the sway bar up.....
