T-case repair | Ford Explorer Forums
T-case repair
canche
Guatemala city
'91 Eddy B.
Hey guys I am new here so maybe I will ask something that you will laugh at, but I have to do it.
My 4wd doesn't work, I have the electronic one in a 91 eddy B edition and when I push the 4wd H I get a lot of noises, and it feals like the t-case is going to fell down, and if I push the 4wd L it doesn't workat all.
So some people told me that I have to change the whole t-case. are they right, or can I have it fixed, by the way I have the automatic hubs.
thank you for all your inputs.
happy riding
i busted my transfer case on my 97 explorer as well. from what i've been told, it's cheaper to buy a used transfer case than to try and fix the broken one. go to a scrap yard and find one. you should check and see which transfer cases are compatible with your truck. i'm not 100% sure, but i think a 1994 explorer's transfer case will be the same as yours. hope this helps. or you could always upgrade if the $$$ is burning a hole in your pocket
If you need one I have one available.
Originally posted by Diff Whack Daddy
Okay, I finally have a break down of the leftover parts. All shipping charges are the responsibility of the buyer. I am also going to T-haven in January so for larger items I can deliver their. E-mail me for info or if you want pics.
*Electric shift transfer case w/out shift motor ($400), with shift motor ($450). Shift motor alone ($65)
damn. if you only had a 95-97 ex i'd be extatic
