T-case wiring Q | Ford Explorer Forums
T-case wiring Q
White98
PA
'98 XLT
I was hoping that someone could help me out here as you have in the past. I was the guy with the 11 DTC's a few weeks ago. Everything has been running great since then, but I still have an issue with the x-fer case wanting to engage during heavy accel. I believe that it is the x-fer case clutches and or some type of speed sensor telling the case to engage. If I disconnect the square harness plug at the t-case, I can drive the X around with the engagement problem gone. It will spin tire in "2wd". Once I reconnect the harness, the problem comes back. I was hoping someone caould point me in the right direction here. I would be looking for the wiring diagram of this particular harness so that I can back track this issue, B/C I have a feeling that is electrically related. If you have any other suggestions, they would be helpful as well. Thanks...
