CABAL
- February 9, 2015
- Texas
- 2002 Sport Trac
Hi, guys. New member, here. This is my first post. I own a 2002 Sport Trac with a 4.0 V6 SOHC engine with around 170,000 miles on it. I've had it for about 4 years and have always kept up with proper engine maintenance. I started noticing a heavy antifreeze smell for the past couple of weeks, whenever the truck is running. It only smells on the outside, though, and not inside the truck. I've been checking the radiator every weekend since then and it's usually missing about the amount of fluid that fits into a soda can. I have checked all over the undercarriage and hoses for leaks, but haven't found any. I did notice a bit of clear water coming out of the tailpipe, today, but no smoke from anywhere and it has never overheated. Just enough water leaked to leave a small puddle. I had the truck raised from the front on ramps. I also followed the muffler and noticed a drop of water forming right where it connects to the catalytic converter and a "wet" hose going to the upper front of the radiator. Does this necessarily point to a blown head gasket or something less costly to repair? I do the basic maintenance work myself (oil, fuel filter, plugs, etc.) but I would have to take it to a shop for the tougher jobs and this is my only vehicle and mode of transportation for work. Any help will be greatly appreciated.
