Yep yep -- but read up on it cauz there are some other aspects of it like:
1) the shifter which will interfere with your center console so drop the console or go with a shorty style
2) the 4wd lights on the dash will blink but you can reconnect the sensors to fool it, or other methods
4) your front axle is vacuum actuated (called the "CAD" or central axle disconnect), but theres an easy way to manually operate this (with an electronically actuated vacuum valve feeding off of the engine's intake manifold vacuum i believe).
EDIT - oh and I was wrong on reply #11. I thought you had a 1st gen but now I see you have a 2nd gen. You have a Borg Warner 4405, not a 1354. But doesnt matter, the 1354 manual will still work for you.
