MadExplorer93
- July 25, 2007
- Sault Ste Marie, Ontario Canada
- 1993 XL 4x4 4.0L OHV V6
A little more of an update, nice out this morning warm outside so i decided to test the MAF connector and the Relay Pump connector wires and ECC Relay Connectors.
I never started truck and battey Volt was 11.75v
This was KOEO:
The Relay Pump Connector wires in power box and the ECC wires showed proper voltage 11.75v for the power and ground part of it. The other two connections never showed anything, nut sure why, but maybe they don't till enigine was running, but how to test it afterwards when running?
I check the MAF wires and the Power was 11.68 RED wire and i grounded to Battery Ground at BAT terminal, The Ground wrie = Black Wire also showed similar result when i touched the RED/Black probing with my Volt Meter. The Tan/Black stripe wire showed 5.75V and the Blue/Black showed 0.5V.
I do believe those readings are correct therefore the MAF itself must be either malfunctioning or i may have a PCM issue not reading right. Remember i get a Relay Issue Code and a MAF reading under minimum amount.
If anyone can verify my readings please let me know?
Now i no battery was a low reading 11.75 even though vehicle starts fine it is a DEAD battery in the world of backyard mechanics as it should maintain at least 12.65v no prior starting.
This was KOEO:
