Exploderpilot
- November 7, 2003
- Nuevo, CA (where?)
- 07 Titan SE
burns, wanna put me up if i fly out?
You do know.. . that you're closer to more serious rock crawling than we are right? Instead of Tellico, there's Calicoi am really stoked about seeing real rock crawling.
Weld the rear, and maybe an Aussie in the frontWell i will not be open f/r while im there. If i have to weld both diffs up i will.
Im coming, and i'll be in the hard group. I should have an ARB rear with 5.13's and a welded front and 42's
I say you just weld the rear differential -- spider gears for the 8.8 are everywhere so its easy if you decide to go back. With a full spool, you have to set the ring and pinion all over again (but not with a mini-spool).Thats prob what ill do or spool rear/aussie front
You have the furthest drive I think.Im coming, and i'll be in the hard group. I should have an ARB rear with 5.13's and a welded front and 42's
