jobar
- August 16, 2011
- Berea, Ohio
- 2005 XLT
Had no air so naturally replaced the blend door actuator. The actuator is working fine, door opens & closes when you switch from heat to air, but it just blows HOT air. The hottest, in fact. The only way to adjust the temp is to open the windows! We got it to manually switch over to A/C one time & it would blow only cold air. Again, no temp control. Any ideas?
