XonDubs
- September 5, 2003
- wisconsin
- 97 5.0 AWD Limited
Ok well, here goes nothing. This is on my 96 Limited 5.0 AWD with 120k miles.
The radiator sprung a leak, so I put in a new radiator, thermostat, lower radiator hose, and flushed the entire system, and installed a new temperature gauge sending unit(the one wire one).
The gauge goes all the way up to that line before the red and the "check gauge" light comes on.
My questions are, how often do these gauges go bad?
The instrument cluster, for some reason was swapped out to a 5-speed cluster. Would that change the reading of the gauge? Like do the 2 different clusters have different values? I don't know if the cluster came out of a V6 5-speed or a V8 5-speed(if there is one)
Also, what sensor/sending unit does the DIC display in the center counsel use for when it does the "system checks"?
Because when the gauge is that high, and the "check gauge" light is on, the DIC tells me that the engine temp is "OK".
So does this get it's readings directly from the computer or no?
Thanks in advance for any help.
