hmmmmmmmm............. you've got quite a delimma here. you see, its pretty easy to get more PEAK torque in a 5.0X, but more LOW-END, thats a different story. i assume all you want is more torque in the 1000-2300 rpm range. kinda hard to do, considering what you have to work with. the 5.0 in the X is pretty much the same as the 5.0 Cobra motor. the intake and heads were really designed for midrange-upper power. to get more low end/fuel mileage, ford used a very small cam. didnt really work that well, IMHO.
basically, you need to set about looking for good compromises. the headers will be worth it, just to get rid of the annoying tick, and they really arent much different than the stock headers, the FRPP's just dont have the restrictive "dimples" in them. you may loose 5 ft. lbs. off idle, but gain 10 ft.lbs. @2000 rpms. prolly wont even be able to tell the difference when towing. the FRPP headers are kinda small and short, so if there ever was a header engineered for torque, these are it. doesnt really matter, as this is the only aftermarket header for the 5.0X anyway. also, if you dont have a catback exhuast, they really arent gonna do anything.
if you have the stock airbox setup, then get a K&N and cut the box in half. at the very least, pop out the "air horn". the hole in this thing is like 2.5" in diameter, and there is no way that even a stock 5.0 can get enough air through it. this will help midrange tq. some, but will prolly do nothing for off-idle.
the ultimate off-idle torque mod would be to use an intake manifold from a late 80's to mid 90's truck 302. the intakes were considerably taller with longer runners, and made more low end with a sacrifice of upper rpm. horsepower. sorry, but the only way to do this would be to run a hoodscoop, as the truck intake will not fit under the hood of the X (why ford didnt use it in the first place).
the absolute best thing to do would be to go with a cam. find a good low-mid rpm cam, and you may loose a few ft.lbs. of torque off idle. you will, however, see some really good gains in the 1400-up range over the stocker. basically, sacrifice a minor amount of off-idle to get alot more "cruising rpm" tq. for towing, you dont care if you loose some at 1100 rpms if you gain 20 ft.lbs. at 2400... which is right around were your motor will be at 90% of the time towing.
i get the idea you want more off-idle. this, my friend, may be harder to do in a 5.0X than it would seem. but really, you could concentrate more on low-midrange, and be just as happy. best thing to do right now to get that trailer down the road would be better breathing (intake, exhaust, FRPP headers.) while it may make your #'s a little lower off-idle, it will help quite a bit for your 2000-2500 rpm range. basically, it may take .5 seconds longer to get that trailer up to 55mph, but once your there, it will hold speed ALOT better. i dont think you will be dissapointed. i tow with mine, and even though i didnt do my mods with low-end in mind, its still alot better than it was stock. (i have towed with mine SEVERLY overloaded before).
sorry for the insanely long post, and if you have more questions, just ask. i promise, i will try get more to the point in further posts...
