We made a huge milestone on Sunday. The Navajo made it off of the jack stands! I have a place to do the alignment and install new tires just 4 miles up the road from me. The new exhaust is on and new shocks and rear shackles. Rear diff was sucked out and refilled. I will pull the cover this fall and do a good cleaning in there. We had some problems with the Rockauto tie rod ends as mentioned above. The new MOOG stuff fit as intended. I'll need to tend to some body rust around the corners this fall, but nothing too major. I sanded, primed, and painted all the rust spots under the truck when I was working on it to add some life. That one type of Rusolium primer that converts rust to a paintable surface is pretty darn good stuff.
Today I picked up the new fan clutch, water pump, heater hoses. My Lang fan clutch tool arrived today as well. Since I have to replace the fan itself, it seems logical to replace the other parts. And I was going to replace the U and L rad hoses anyway. So with the system open may as well do it all, right? I could not find the T with the valve that connects to the heater hoses into the firewall, so I hope that is still good. Oh, I also picked up a new radiator cap. Any special tricks I need to know when doing this water pump and hose work? I presume you just burp the air out of the system like any other vehicle with the radiator cap off?
