Jon what tranny did the output shaft come from and was it solid or hollow in the center of the shaft,looking at the end where you cut it off? You are using the 1350 as the doubler & the 1354 as the transfer case, right? I'm actually thinking I'll build one using the 1350 for the transfer case & 1354 for the doubler.
Talked with the engineer about shaft strength & he was able to quickly pick up the Borg Warner info for both cases...I made the tire parameters around the big meats you traded for (35x15.5x15) if I recall correctly, 4200 pounds, and 250 hp I wanted to be on the high side just to be cautious...he thinks other parts in the drive line would probably fail before the shaft given that automotive testing of trans, transfer cases and differentials are carried out at about 3 times the maximum real world usage requirements and stressed by extreme temps and minimum lubrousity for hundreds of hours to part/unit failure. That was good news however I did not have any info on that "weak link shaft" of unknown, to me, origin and construction...but he felt that if it was not a hollow core shaft and that the diameter was not turned down significantly (have to get back to him on that one) it should hold up. Of course he also stated that my limited skills as a welder would probably be the real weak link in the projects viability! I'd fire him if he still worked for me. He also recommended heat treating of the finished shaft assembly...typical engineer. If you could answer my initial questions I'll get back to him for you. Thanks Rick C.
