The bog and die curse | Ford Explorer Forums
LOCKONS7RA7US
Location
Everett , wa
Everett washington
1992 , eddie bauer
Callsign
Taco Run
So i have been plagued with this curse for some time now and orignally started in 2015 did some fixes with sensors and throttle bodies and got it fixed to a point for it will run n drive moat codes went away other than one. Which was 124 i believe i talked to FR on the forum and told me i have some wiring issue.. amd never got around to it.
But now here in 2021 after the snow storm we had here a month or so back.. it started acting up for no real reason would be running then all the sudden not want to run . Jump the post on the start solenoid and was back to normal .. ao then i basically went down this rabitt hole of replacing charging system.. replaced starter case post snapped off , replaced alternator and battery alternator over charged battery and killed a cell . , new starter solenoid . also the 4x4 shift transfer case motor was locked up and replaced that ..
I would start the car , turns over fine and idles fine idles roughly at 1000-1100pretty normal for it .. but after its warm enough 10 -15 min warm up i would go and drop it into reverse and it would try to keep its self running but then just die stop running . I will have to put it back in park then restart then put it into neutral then reverse and the rpm would drop to 500 then when i go back to drive or over drive it would be idling back to almost the same 900rpm in gear but no issuies while driving or stopping at a light.
Ran codes koeo
- 124
- 157
Went to clear codes and then got
-551
Did codes while engine was running
And only got 10 for several seconds then these 2 twice and that was it.
-536
-538
After receiving the 157 code .. i replaced the MAF and it had no change ..
It looks like i have a electrical gremlin and really need help with this gotta break this curse
