dasfinc
- February 11, 2009
- 1999 SOHC Exploder
I picked up a 99 4.0 SOHC truck on the extreme cheap that had a cold start rattle (the typical tensioner symptom of just a few seconds of loud rattle, then a super minor rattle until warm.
Replaced the front and rear cassette tensioners, and a fresh synth blend oil change (albeit a purolator filter), and the rattle is now rather random on start (one in maybe 3 cold starts it rattles), and once it's done with that start-up rattle it's dead quite/smooth). The rattle is much shorter/quiter, and like mentioned, intermittent.
Thoughts? Primary tensioner? Should I toss on a better oil filter? (Which ones have the appropriate non-drain back style etc?). Truck has 109k on it, and seems to have been reasonable well maintained.
Will likely tear down in spring once I pull the mustang out if storage, but would like to be 100% confident it will be stout for winter.
