Got a question for you. When you turn the key over to the RUN position, (not START), can you hear the fuel pump running for about 3 seconds? If so, your fuel pump relay is probably good. If you don't hear it, it could be either the relay or the pump itself. If the truck does actually start, I would say your pump is working as well as the relay.
How long do you have to crank the engine before it starts? If it takes more than 3 or 4 seconds to start, it could be another problem. It could be a faulty check valve in the fuel pump. The check valve is designed to keep the fuel system pressurized when the engine is turned off. This will make the engine easier to start by not having to build up fuel pressure when it is restarted. If the check valve is bad, it will let fuel drain back thru the fuel system and go back into the tank. If this happens, it will take a short time of cranking the engine before the fuel is picked up and gets to the injectors.
Does the engine start right back if it is shut off and then restarted within a couple of seconds? If so, I would think it is the fuel pump check valve which means the fuel pump would have to be replaced. Something you can try to verify this, after it has sat for a while without being started, turn the key to run and allow the pump to run until it stops (about 3-4 seconds). When the pump stops, turn the key off and then back to run for a few seconds. Continue doing this several times without actually cranking the engine. After going thru this process for about 30 seconds, try starting the engine. If it starts right up, replace the fuel pump because the check valve is bad.
BTW, most people here on the site think of the FPR as the fuel pressure regulator instead of the fuel pump relay. I know it can get confusing. The fuel pressure regulator usually gives problems while the engine is running. These problems usually start with a check engine light after running 10-15 minutes. When it is defective, you will usually experience rough idleing, poor engine performance, as well as lowered fuel economy. This can occur all the time or just intermittently as mine did. Believe me, I still remember the headaches.
[Edited by Ira on 11-14-2000 at 04:04 PM]
