Thermastat reads wrong temperature and direction | Ford Explorer Forums
ladystephanies
Waterville, NY
1997 XLT 2002 XLT
Hi I have an 02 Explorer XLT that the inside temperature gage and compass does not read right. It is June and it says the temperature is -40 which i know is not right. I need to know how to fix this and where it is located. Thanks so much.
Check the owners manual.
For sure there is a calibration for the compass.
I dont think there is one for the temperature. Sounds more like the temp sensor to me.. is it always on -40°?
Make sure you're using correct terminology....you are referring to a thermometer, not a thermostat....two completely different things. If you walk into an auto repair shop and tell them to change your thermostat...trust me, you won't achieve what you are wanting! :cool:
Thanks the calibration worked. Now i need to know where the outside temperature sensor is and where i can get a replacement part for it.
