Marty
- April 18, 2000
- Kingsland, GA
- 94 Navajo
Truck: 1994 Mazda Navajo 4x4
Problems: Radius Arm Bushings (big surprise, huh?)
I am debating on replacing the bushings myself. I will use the drop the spring method. I don't want to grind the rivets and go through that.
I have read a number of posts on here, and have been reading post after post. I read all kinds of different stuff. If I do this, I want to do it in a way as to not cause any damage to the truck, such as u-joints, etc.
As I understand it, I am going to put the truck up on jackstands supported on the frame. And then:
1) Remove the 28 mm radius arm bolt.
2) Unhook the sway bar.
3) Remove the shock from the bottom mount
4) Remove the bolt/nut from the bottom of the spring mount and allow the suspension to swing free.
The question starts here. Once this is done, is it difficult to pull the suspension far encough forward to get the radious arm to slip out of the bracket so that I can put the new bushing on? If it is difficult, how do I do it? Is there anything else I need to remove or loosen to make this work? What are the risks, and how to I minimize them?
I have heard things like:
Loosen the axle pivot bolt and be carefult when pulling the suspension forward.
What should be added to these, and are these necessary.
