Throttle Cable 94 Still Available? | Ford Explorer Forums
massacre
Massachusetts
‘94 Explorer
‘19 Nautilus
Mice chewed the insulation off my throttle cable. Throttle sticks sometimes so i keep spraying it. It's kinda dangerous so I would like to replace the cable. I'm not seeing anything available.
Would anyone have the part# for the throttle cable? Or are there aftermarket cables that aren't too tough to install?
Thanks for any help
Thanks for any help
F1TZ-9A758-F ford
zzl041600a mazda
Those are likely not helpful. If you are against pulling from a junk yard, you could be adventurous with:
FO173 CAHSA
Dorman DL869A
You are on your own with that. Remember those prices are pesos.
Tried starting my 04 accord yesterday. *wump *wump *wump. No dice. Open the hood and a rat was sitting right on top the manifold. ran off.
Had taken a section of the MAP harness into the cozy center of the v6. Also took the knock sensor wire.
I have two 92-93 trucks for parts if you need a throttle cable I can get you one
If the cable is the same, i'm interested. No junk yards around here with 1st gen explorers unfortunately.
I'm not opposed to a used cable at all, thank you 410!
I set you a pm
PM received:)
