Guinness
- May 20, 2003
- Anchorage Alaska
- 92 XLT
Could anyone tell me what the connection leds to the Throttle Position Sensor should be reading with an ohm meter? I have unplugged the battery, switched on the headlights to drain any charge, waited 15 minutes to clear the engine computer codes, replaced the sensor with a new one. Reconnected the battery, drove it to re-learn the codes, but the computer still reads out a problem with the sensor. Is there a trick to replacing a throttle position sensor? Thanks for the replies people.
