itslikewhooa
- July 11, 2010
- salem NH
- 2000 XLT
Ok so lately I've been hearing a sound coming from the rear of the truck although I cant be absolutely certain because it only happens when I'm driving... I took it to a trans. shop near me and had them take it for a drive.... they said it wasn't the trans. and that the sound was normal... well I know that a loud thud noise isn't normal. so hears the problem
when driving usually around 30 -50 mph if I take my foot off the gas and then tap the gas, there is a loud "thud" noise, again I believe coming from the rear of the truck. during normal take off from a stop through all gears it doesn't make the noise at all, and shifts fine and smooth.
the trans. place put it on there lift and said everything was tight and nothing seemed loose. I'm going to jack my truck up my self and double check them. because they also said the noise was normal.
could it be something in the rear diff. ?..... I read somewhere that the axle sleeves are only pressed in and not welded...I do tow some heavy weight behind the truck could those have loosened up?... I'm going to check the u joints myself. or is it something I'm not even thinking of....
any help would be appreciated
thanks in advance -Ross-
