Thunking Noise | Ford Explorer Forums
Thunking Noise
mzcie
Sacramento, CA
'94 Sport
Thanks to many of you it's been a long time since I've needed to be on this forum. Now I have a new problem and need to research it prior to repair on my '94 X, manual 5-speed, 104k miles. I have a thunking noise in front of the transmission when I go over bumps. It sounds like something's come loose and vibrating, and it's very loud. There are no other symptoms. It runs great, there's no braking problem, and no abnormal exhaust noise. I'm hoping it's just a broken bracket, but I'm not usually that luckly. I've read through the forum and it seems the most likely culprit is the radius arm bushing. Am I headed in the right direction?
Thanks, California Lady
my 91 does the same thing. over bumps or stopping in reverse it clunks. im not sure about the 94s but on mine the cat is right next to the right radius arm bushing which melts the bushing til it falls off take a look at that it could be the problem
Yep, sounds like radius arm bushings.
