Timing chain rattle. | Ford Explorer Forums
adam exp
norfolk
97 4.0L v6
hi i am a new member to the forum and was just wondering about the engine oil for my 4.0l v6 sohc ,it says about semi sin but would full sin be any better as i have the chain rattle on start up for a couple of minutes or is there another option to help without stripping the engine apart as money is a factor,
thanks.
I've been running full syn from mobil 1 for the past 12,000 miles or so...doesn't seem to have helped the chain rattle that much. I'm pretty sure that once it starts rattling at start up and often when hitting the 2,600 rpm(yours may be a little lower/higher) mark it is only a matter of time. I plan on replacing the chains/guides in the front at least this summer. Good luck
welcome
I too had this isuue and started running synthetic and it worked
