07EddyB
- November 18, 2011
- Bowling Green, KY
- 2007 Ford Explorer 4.6 V8
I've had a bit of chatter lately but only for a few seconds at start up. A few weekends ago I had the right valve cover off to check on a follower that I replaced a few months ago and noticed that my right timing chain had some slop in it where it went back down to the crank. I assume at this point that there should no slack even with the engine off and I need to replace that tensioner (6L266). So I'm looking around for parts and I can find the tensioners but while I'm in there I also want to replace the plastic pieces that tend to fail. As I understand it those are referred to as the 'guides' (6M256 and 6B274). There appears to be another 'tensioner arm' (6L253) that I assume goes against the tensioner and holds the chain against the 'guide'. So do these tensioner pieces need to be replaced also?
