Raceit
- August 28, 2000
- Overland Park, KS
- '91 Explorer 2DR 4WD XL
I've done some searching and didn't really find an answer to my question.
Is there anyway to "check" the tension on a timing chain without actually tearing all the accesories off the front and actually looking at it?
I fear mine is very loose. The engine has about 200K miles on it and it has a funky sound to it. It will do it with a load on the engine and even when you are going down hill and the engine can run with the speed of the vehicle (it's a A4LD tranny). You can even hear a "metal" type sound at idle.
The lifters were just replaced along with the rocker arms and push rods. So I would assume I could rule those out. It doesn't really sound like an octane knock. It will do it just the same with either 87 or 92 octane.
Thanks!
Thanks!
