Jerry D Finley
- February 3, 2024
- Fairview, NC
- 2014 Explorer XLT
4/22/25- AWD Life (and Tire) Lessons Learned:
Just a follow up concerning what to do if you end up with a unfix-able flat or damaged tire on your AWD Explorer rather than replacing all 4, which many here and there have advocated.
Over the last few days I learned a lot on the subject and came up with two viable options to spending big bucks on a full 4 tire set should you be caught (or cursed) with one damaged tire like I was...
1. If you end up with a damaged tire, take the tire to your local tire store and let them measure the tread depth (It's only takes a couple of minutes.) In my case the tread depth for all 4 tires on my 2014 XLT was 8/32nds. In actuality, it's best if you can take your vehicle so they can measure all 4 tires.. With that information in hand, contact any reputable tire selling company like TheTireRack and order a single replacement tire .. same brand.. same tire model ... same size and have them shave the tread down to (in my case.. 8/32nds) to match your other 3 tires. The shaving service is $30 on top of the price of the new tire... You'll save yourself about $600 or so... or..
2. There's a massive tire company in Chicago called UnitedTires and they sell exclusively on eBay.. They sell new and used tires... If you go to eBay and type in the brand, size, and model used tire you need to replace your bad one.. (in my case it was a MaxTour LX GT Radial 245/60/R18) you'll get dozens of listings of that specific used tire in various tread depths.. In my case I needed 8/32nds and they had quite a few used Maxtour LX GT Radials for sale with that exact tread depth. Price was about $88 delivered for one or around $175 delivered for (2). They guarantee satisfaction or your money back. Instead of buying an entire set of 4, you simply buy one used tire to match your other 3 with the same tread depth. You'll save at least $700....
Hope this helps somebody...
4/21/25- UPDATE:
Well got this problem solved or at least in progress.. Spoke to my go-to tire rep an hour ago (at the TireRack.com). I've been buying tires from them for over 25 years.. He said to buy a new tire to match the others and they'll shave it down for $30 to match the others... so.. I took my Explorer to the local Discount Tires and they made all the measurements, I forwarded those to Tire Rack and placed the order... Bam.. Done.
In the 70 years I've been on this earth, I've never heard of a tire being shaved.. I learned something today...
Thanks everyone for all the advice and suggestions...
_________________________________________
Started the day with a flat tire on my 2014 Ford Explorer XLT.... Put the spare on and took it to the nearest tire repair store... I just left there with potentially bad news... Need some advice...
The tire guy said that the tire can't be repaired, but he could NOT sell me a new one because if you mix a new tire with 3 others that are 1/2 life or better.. it would damage or even ruin my all-wheel drive transmission.. He says my only options are A buy all new tires or B. find a used tire place and look for a same size tire with the same or within 2mm tread depth and have it installed.... Before I left the store he turned off the AWD feature.
I was prepared to have to buy a new tire... but not 4 !... Worse case scenario, couldn't I buy both rears so they'd match height-wise in the rear? Is all this true? I've never heard of such a thing... Opinions welcome...
4/21/25- UPDATE:
