Tire sizes | Ford Explorer Forums
Tire sizes
Fayetteville Georgia
05 explorer sport trac
I have a 2005 sport trac 2wd. What is the biggest tire size that I can use without any cutting? If i do end up cutting what is the biggest tire size i can go with stock height. Or if I get a PA 3 inch body lift what is the biggest size tire I can go with?
I guess all I'm trying to ask, is for options for making my sp look bad a hell.
All comments are appreciated
Stock height and stock 16" wheels, you can do 265/70/16's with zero trimming.
jerry (midnight) hit it on the stock ride height.
the ease of adding a leaf like me or hugh (offtrac) and torsion twist is worth it to get 265/75R16 which is approxamately a 32" tire combo. an even easier option is shackles rather than add-a-leaf. this lift nets around 1.5-2 inches of lift.
a body lift alone you can barely squeeze in 285/75R16 which is approxamately 33"
if you do both lifts then its very common amongst members to run 33" tires
lift
where could i find the shackles for a lift to get the 75r16's to fit as well thanks!
Tellico is where I bought mine.
