maxmjmmat
- January 11, 2013
- Napa, ca
- 1993 ford explorer
After reading the awesome write up on clutch/ flywheel replacement i decided it was time for my x. Got everything back together with new atf and all and came to the last step: putting the top shifter back on. Im having a big issue and cant seem to find a solution on any of the threads with similair prblms. I slip the shifter into the gear box exactly where it seems it should go and it wont go into gear. It moves horizontilly as if its in nuetral but wont go vertically into gear, engine off. Had no issues with the slave. Had it in nuetral when i removed it. I also have the heads off so i cant start it. The input shaft went right in, the clitch pedal has normal stiffness and with the rear driveline off the transmission wont spin-locks both ways. Im totally stumped...
