DTD
- November 11, 2009
- 1995 eddie bauer
Hey guys, Im new to the board and I see Im not the only person that's having problems with their explorer! I have a few questions. First, I have a 1995 ford explorer eddie bauer, which has the 4r55e tranny in it.
First, I bought a replacement transmission to put in my explorer (dropped 4th gear or OD in mine) and I ran into a slight problem. Where the input shaft is, there is a secondary shaft inside of it. What is this called? This fell out on me and I stuck it back in but fear I didnt do something properly. I stuck my torque converter on and I couldnt seem to get that secondary shaft it fit. Also, when the torque converter is installed properly and you turn it, does the output shaft turn as well? This secondary shaft Im speaking of wil turn that output shaft w.out the T.C., but once I installed the T.C. that output shaft was turning but the torque converter was. Im no mechanic so im totally clueless! Also, whats the best way to pull the shaft back out and install? How do i properly install the torque converter? This tranny I bought has 130,000 on it. I replaced the pan gasket and filter. Should I replace anything else upon installation?
Thanks for any advice and thanks for having me on the board
Also, THANKYOU TO ALL THE MILITARY VETS ON THE BOARD!!!
