Corik
- July 15, 2011
- CA
- Explorer '91 XLT 4x4 A4LD
Hey Mr. Shorty I was wondering if you can explain the output state test. So I preform the KOEO test and after it is over I push the throttle to cycle through different tests right? how many times would I need to push the throttle before i come across the test of the transmission solenoids?
and I'm a little confused so let me make sure I understand correctly, "IF" the PCM commands the TCC to lock I should then get 0 volts?
I retested the #53 wire on the PCM, the TCC wire. I guess I wasn't touching the wire well enough, this time I got 12.3volts with key on.
I was in auto class at school, we were testing the cooling system. I brought my car in and noticed that my top hose was hot and I only had the truck on for about a few minutes and I think my thermostat is shot
I just thought I'd ask at what temperature the thermostat opens. in case I decide to buy a new one.
I'm going to test it again tomorrow, so I should turn on the truck cold and put my hand on the top hose right? and if the hose warms up slowly then I know its a bad stat right? Because its supposed to be cold and all of a sudden get hot because the stat should open and not be completely open all the time.
I know i ask a lot but I want to learn
